300 rear main seal
Posted by chrism in tn on June 11, 2011 at 18:53:41 from (96.38.35.2):
I have my 300 split to change the clutch, would like to do the rear seal, it leaks a little. Anyone have instructions? The manualjust says it should be apparent what needs to be done! Does the oil pan need to come off? I can't figure out how to support the engine side (right now it is on a floor jack) and be able to remove the oil pan if it is needed to do the rear seal....
