Farmall Super C Genertor gets very hot
Posted by Tobacco on June 18, 2011 at 14:31:30 from (71.225.179.124):
I have a farmall super C that I recently had the generator serviced and put on a new V.R. and coil. The generator gets so hot that you can't touch it and the coil gets hot. Is this normal or have I wired something wrong. I hand crank this tractor to start it, battery is dead. However it does show discharge when the switch is pulled out and charge while its running now... I have cleaned up the ground on the POS and NEG terminals on the batttery and where they bolt to the frame and starter.. any suggestions are appreciated..[/b]
