Re: Farmall Super C Genertor gets very hot
Posted by Owen Aaland on June 18, 2011 at 18:43:56 from (216.47.33.237):
In Reply to: Farmall Super C Genertor gets very hot posted by Tobacco on June 18, 2011 at 14:31:30:
If the battery is dead your generator will get hot when it is running. It is going to be at maximum output all the time.
There is no provision for cooling on those generators so the heat really builds up ion them when the run at maximum load. Try charging your battery first and make sure that it is good and will hold a charge. Once the battery is charged I think you will find the generator will run cooler.
