Re: Re: Re: Rear Wheel Removal
Posted by Fudd@Work on August 06, 2000 at 22:10:30 from (205.242.73.10):
In Reply to: Re: Re: Rear Wheel Removal posted by Jon on August 06, 2000 at 19:12:23:
Hi Jon: If the back tires are dry, it is easy to take them off. Have someone help you so they don't get off balance. Jack up the rear to take the weight off the tire but leave it on the ground. Remove the clamps, then raise or lower the axle so the wheel is in the center of the rim. Now you can just slide or roll the rim/tire away from the wheel. Good luck and be carefull.
Post A Followup
: Re: Re: Re: Re: Rear Wheel Removal
