Re: Hydro troubleshooting
Posted by Owen Aaland on June 18, 2011 at 17:33:28 from (216.47.33.237):
In Reply to: Hydro troubleshooting posted by Bill46 on June 18, 2011 at 09:12:12:
How are you checking the oil? The PTO dropping out after a little bit of running suggests to me that you are checking the oil level without having the engine running. When a hydro runs it fills the hydro section of the tractor completely full of oil. The oil pickup tube is between the rear axles. If the oil level is at the full mark with the tractor not running it will be seriously low while in operation. That could explain both of your problems.
To check the transmission/hydraulic oil in a hydro the engine needs to be running for at lease two minutes before you check the level.
