Posted by Tyler Jackson on June 19, 2011 at 17:01:48 from (75.207.96.90):
In Reply to: Fuel blockage posted by LRRifleman on June 19, 2011 at 16:11:01:
I don't think your problem is in your tank. To check take the glass bowl off and stick some wire or someting up there to see if it unblocks it. If not it's probly somethin in your carb. My H did the same thing with the gas flow. Some one who knows a little more about carbs can probly explain whats wrong but what I did to fix mine is open the drain on the side of the carb to get the air out and that did the trick.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
