Re: Fuel blockage
Posted by CNKS on June 19, 2011 at 17:26:20 from (216.144.104.128):
In Reply to: Fuel blockage posted by LRRifleman on June 19, 2011 at 16:11:01:
No baffle, loosen the nut below the glass bowl and the fuel will flow in. If not, your tank may have debris in it, you can clear it most of the time by putting a wire inside the tank into the outlet. May be a little difficult with that particular tank. Also, the carb inlet has a screen inside, it could be plugged.
