Hi Okie, do I read you correctly that the front loader works OK? How is the loader connected to hydraulic system? Is it connect to rear remote outlets? Is there a separate hydraulic pump connected to crankshaft on front of engine? Is the transmission full or over full on the dipstick. It does not hurt to overfill by 5 gal. Was the filter physically the same as the old one?
The 574 only has one hydraulic pump that puts out about 12gpm and the MCV splits the flow into 3 gpm for PS,PB and oil cooler and 9 gpm for 3pt and rear remotes. Sometimes after a drain and refill, you have to place a bucket under MCV valve and loosen the connection to the PS line on the left side of MCV valve. The MCV Valve is behind the hydraulic filter. Start tractor and let run until hydraulic pump primes itself.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
