Posted by Okie574 on June 19, 2011 at 15:57:31 from (166.205.11.71):
I recently changed the hydraulic fluid and filter in my International 574 tractor with an International 2050 front loader and now the rear lift, steering and PTO will not work. Everything worked fine before the fluid change, but was starting to get whining noise with the hydraulics.'the fluid was very milky from water/moisture. The front loader operates as it should. I used a Wix filter and Mastertran fluid (New Holland replacement for HyTran). Do I have air somewhere in the system? Anyone know how to bleed the system? I have drained the fluid and "flushed" the case with diesel, re-filled with fluid and installed a new filter, but no change.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
