444 pto shift lever repair
Posted by Tom Mnj on June 20, 2011 at 05:11:22 from (198.177.1.25):
This weekend when getting ready to make some hay the pto shift lever became free when attempting to engage.I pulled the loose lever from the housing and observed a pin hole at the end of the shaft. I am assuming I need to replace the pin. I would appreciate your advise
on how to proceed with this repair. Am I correct in assuming that the top housing will need to be removed? Are there any tricky mechanical issues that I need to be aware of? Your advise is greatly appreciated.
Thanks
Tom
