Re: 444 pto shift lever repair
Posted by JimB2 on June 20, 2011 at 16:55:30 from (99.240.236.11):
In Reply to: 444 pto shift lever repair posted by DeltaRed on June 20, 2011 at 05:11:22:
Hi Tom, looking at caseih.com parts, it depends which pin is missing, if item #4 has come off the end of shaft item #2 then it will be more difficult than when the pin shears off the bottom of item #4. If it is the pin that fits in collar #5, I believe the pin can be replaced and the shaft re-installed by removing the assembly by removing the 3 screws that hold the assembly in transmission. To prevent trans fluid leak, park tractor on slope with PTO lever on up side.
Check the archives as someone had described the repair a few months ago.
JimB
third party image third party image
