That block has the larger holes for the bottom end of the sleeves. I believe your old block takes the small ones. You need to use a sleeve and piston set for that block. I know of no other problems using parts from the old block. I don't see the main bearing caps on the 130 block. You need to use the original bearing caps in the original locations.
You do not need to change the radiator or add a water pump. Just use the Super A water inlet and outlet. Be sure to use a head gasket for an engine without a water pump. A 130 engine gasket set will have the wrong head gasket for use without a water pump.
Looks like Daniel H. and I were posting at the same time. At least we agreed!
This post was edited by Jim Becker at 07:50:10 06/21/11.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
