Big Don, p! Tranny update!
Posted by Scott Hansen on August 07, 2000 at 08:42:40 from (130.187.27.94):
I drained my Cub's tranny and opened up the back plate (there is no PTO, so everything is very visible), and took off the shifter plate. Then I blocked it, jacked it up, and started turning wheels. Now, as information, I have replaced both of the differentail carrier bearings and seals, and I put the shims back as I found them. I also replaced both bearings and seals on the input and output shafts. I think I isolated the noise, but I'm still confused. I even started her up and run it slow in 1st. You can easily stop the running wheel and make the other one turn. Well, I'll just throw out my findings. Contrary to what I was thinking, there is no play in the output shaft. It looks great. There is no noise coming from the differential at all. The input shaft is quiet as well. The noise is coming from the output shaft and the reverse idler. My apologies to Big Don, I had discounted his comment that the reverse idler always turns. I thought it just turning when you were in reverse, hense the name. Fact is (steak dinner for Big Don if we ever meet), it turned all of the time. There is no wobble in the gear, nor the one that turns it on the output shaft. There is a little play so that the reverse idler moves slightly back and forth along the shaft. Some .005 or so. The gears are kind of worn pointy, so that if you turn the wheel back and forth while in gear, you can hear them slap together. The only thing I could guess is happening, is that the gears are slapping when they mesh, or that the reverse idler is slapping against the case when it moves that .005. So, the next thing was to can the 80/90 lube, and try some 80/145. I put a gallon in. Well over the full mark, and low and behold, I could still hear the noise. Just as loud. So, for experiments sake, I filled the entire tranny with 80/145, completely submerging the whole mess. Same noise! Could it be sending the noise through the metal, and out through the case? Before you ask, I'm quite sure that the noise is coming from the tranny, and not the reduction gears or bearing in the wheels. It goes on which ever wheel is turning, and is in the tranny. What to do next? Should I replace the reverse idler? Put a spring washer to stop play along the shaft? Should I replace the gear on the output shaft? What do you think? As always, I'm grateful for any comments!
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
