Re: Farmall Super C Starting Issues
Posted by CNKS on June 21, 2011 at 17:59:50 from (216.144.104.128):
In Reply to: Farmall Super C Starting Issues posted by Paul in CT on June 21, 2011 at 17:26:09:
When you replace the head you have to set all the valves to specs. Also, I assume you removed the manifold, could be that the intake is sucking air, particularly if you didn't replace the manifold gasket. Sometimes, the so called experts that repair carbs don't get it right. As simple as those carbs are, you should do it yourself.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
