Farmall Super C Starting Issues
Posted by Paul in CT on June 21, 2011 at 17:26:09 from (70.138.1.157):
I am currently working on a 1951 Super C. I had sent the carb out to be rebuilt. I pulled the head because I has a couple valves that were stuck. Got those moving again and reinstalled the head with a new gasket. New points and condenser gapped to 0.020. New plugs gapped to 0.023. Put the rebuilt carb on and connected the fuel line. I have a good stream of gas to the carb. Tried to start it and it would not fire. Poured a cap full of gas in each cylinder and it ran great for about 5 seconds. Would not start after that. Squirted some gas into the air intake side of the carb and closed the choke. Ran great for about 5 seconds. Would not start after. Pulled the carb and the float is wet so I believe gas is getting in the carb. The idle screw is set to 1-1/4 turns out. Basically the only way I can get it to run is by squirting gas into the carb and then it will run for about 5 seconds. What am I missing? Any help would be appreciated.
Thanks.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
