Hold your hand over the throat of the carburetor while a helper try's to start the engine. If you don't have much suction that means of have low intake manifold vacuum. You may have a vacuum leak around the intake manifold, carburetor base or stuck rings. Check your valve gap and set them at .o17" cold. You probably should do a compression check on all cylinders and compare readings. Hal
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
