Re: Farmall governor help!
Posted by rustyfarmall on June 22, 2011 at 06:32:58 from (216.248.71.224):
In Reply to: Farmall governor help! posted by Bruster on June 22, 2011 at 04:55:23:
Leave the cover off of the governor while installing. That way you can turn the shaft by hand to line up the gears.
The pulsating (rapid speeding up and slowing down) can be caused by a defective governor, or a governor that is improperly adjusted. I have no idea what you are describing as "dieseling", but dieseling has nothing to do with the governor, and in fact, I've never experienced any kind of dieseling in an H.
Today's Featured Article - History of the Nuffield Tractor: Conclusion - by Anthony West. In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. Th ... [Read Article]
