I agree with the other posts. I had milky fluid and was told to over fill by 5 gallons, which does not hurt anything to maintain This level, so I could eliminate any internal suction leaks that could be introducing air into the fluid. If after adding the additional fluid, you still have milky fluid, your gonna have to crack the Tractor and replace an oring like seal between the transmission /differential and the T/A section. This is where the suction tube connects between the 2 sections and drops down into the differential resivour. By the way, over filling will not remove the oring seal issue. Hope this helps, good luck. Tod.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
