Posted by TC2 on June 23, 2011 at 04:29:59 from (132.79.10.15):
I need some help with my M and I knew this would be the place to ask. My tractor has always started the first time it turned over, almost regardless of the weather. I recently pulled the governor off because of a suspected problem, and after I put the governor back on, it cranked for a long time before it started. On top of this, I knew from the last time I had it out, that the valves needed adjusted. Last night, I pulled the valve cover and the spark plugs so I could easily rotate the crank for the adjustments. The spark plugs were wet and black like the tractor was running rich. Anyway, after I made my valve adjustments,I tried to start the tractor. It turned over, and over and didn't want to start. Finally it started with a puff of black smoke. I let it warm up, and shut it off. After about 30 minutes, I tried to start it again, and once again, it turned over and over and finally started with the puff of black smoke like before. It appears that messing with the governor started this whole thing. Any ideas?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
