Re: M Starting Trouble
Posted by pete 23 on June 23, 2011 at 10:48:40 from (74.32.230.16):
In Reply to: M Starting Trouble posted by TC2 on June 23, 2011 at 04:29:59:
But, why was the govenor taken off. When you put it back on you may not have the aligned the carb operating shaft tang properly. It will go on three different ways. Correct way, then below the tang in throttle shaft which would cause engine to run wild and the other way is over the top of throttle shaft and if it is that way the butterfly will not open properly when starting, will possibly sound normal when running but have no power what so ever as the max it can open is about one fourth. I have seen this happen so if you are taking carb off you will be right there to check and make sure you have linkage properly assembled.
