Re: H electrical
Posted by Janicholson on June 23, 2011 at 15:17:34 from (67.72.98.45):
In Reply to: H electrical posted by Tyler Jackson on June 23, 2011 at 14:48:56:
The light bar (that they attach to) might be insulated from the steering post use a jumper cable or similar and find the ground fault. It is not necessary to go back to the main ground at all.
The grounding issue with the steering post/lights has an affect on the charge factor, as the light box grounds the gen field making charge happen. With a ground fault it will fail, or be intermittent. The light switch has control of the charge rate as follows: on L it has a wire resistor in the field grounding circuit causing low charge.
In all other positions the gen is full fielded, through the light switch.
The lights are completely separate in the switch.
I hope this helps. Jim
