If power steering worked ok before you took pumps out, I would suspect the o-ring or gasket between the two pumps. That thin little o-ring is often not included with pump packages and also the thin gasket can be a problem. Some try to sell you the thick one tht goes over the end when you have no power steering pump. And that o-ring from check valve can't get into power steering unless you had no filter as it is a seperate circuit from main pump. You can take the return line off from power steering, put it in a bucket and it should flow 3.5 gals per min of clear fluid, not foamy .
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
