Re: Which PTO adapter do I want ?
Posted by F-Dean on June 26, 2011 at 05:59:42 from (75.207.200.92):
In Reply to: Which PTO adapter do I want ? posted by Super H Mike on June 25, 2011 at 10:11:03:
There is a PTO extension for a Regular just like the PTO extension for a F-20 only it bolts on to the back of the rear-end.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
