Which PTO adapter do I want ?
Posted by Super H Mike on June 25, 2011 at 10:11:03 from (76.164.144.191):
Used the Regular for dragging the driveway yesterday and had a ball doing it ! I want to next use it on the PTO spreader but I see I will require an adapter. Which is the one I want based on cost and quality ? I also think an overall longer adapter would be preffered to reach to where the PTO shaft is on the Regular. Anyone have one that works out well ? Thanks~ Mike
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
