DO NOT hook up any PTO equipment on your regular unless you know for sure the PTO shaft is long enough to stay safely engaged.
The F series have a different PTO to drawbar configuration than ASAE standard. ONLY the factory PTO extension puts the tractor into the ASAE standard that was adopted in the early 40's. The short adapters for changing it to the standard size shaft will let you hook it up but if the shaft is too short and comes uncoupled in the middle when going over a mound or bump, it will beat the he!! out of your regular and possibly you and your legs.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
