Posted by LRRifleman on June 26, 2011 at 18:09:28 from (173.101.76.147):
Hello!
While disking a field last week, I inadvertently ran my tank dry, and I have had problems since then starting the tractor. After I refueled, I could not get the tractor to start (I forgot abot bleeding the air from between the tank and the car). Then, I suspected the fuel filter may have become clog from suspended residue in the 52 year old tank. When I removed the fuel filter, I noticed difficulty in the fuel flow into the sediment bowl. I then removed the sediment bowl, and found excess "corrosion" and particulate build up in the "petcock assembly". I then replaced the sediment bowl and petcock assembly. I still could not get the tractor started, then remember (upon seeing the fuel "trickle" into the new sediment bowl ssembly, that I had to bleed the air out of the gas line. I still have trouble starting the tractor. Today, I took apart the carb and cleaned the needle and jet. Still, the tractor does not start. I then checked the points and rotor, everything seemed in place. In turning the tractor over, it fires up for less than 5 seconds, and sounds like it is firing on only 2, maybe 3, cylinders. Meanwhile, while the starter turns over, the motor and tranny sound like a thrashing machine. All fluid levels show full. After repeated attempts to start the tractor (unsuccessfully) today, I beleive I drained the battery, so that only the starter "clicks" and the tractor will not catch.
Would anyone care to venture a guess as to what is wrong with my tractor to explain why I can't get it to start? As an aside, when I bought the tactor back in '09, it had had th engine (top) overhauled, and since then,I guess I hadput on maybe 40 hours (the tach was disconnected until this past winter whn I had th carb rebuilt and the hydraulics overhauled).
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
