Re: IHC Model 340 Utility (Gas) Starting Problm
Posted by RedRoundhead on June 26, 2011 at 19:40:09 from (173.108.12.225):
In Reply to: IHC Model 340 Utility (Gas) Starting Problm posted by LRRifleman on June 26, 2011 at 18:09:28:
Unscrew the whole sediment bowl assembly from the
gas tank. Take the petcock completely apart. The
inlet pipe may be clogged (the part that sticks up
into the gas tank). This happened to me on a few
occasions. Make sure the screen on top of the bowl
is clean, too. With fuel in the tank, when you open
the petcock, with the sediment bowl removed, fuel
should readily pour out; not trickle. Best of luck!
