Re: 460 Diesel Hydraulic issue, again.
Posted by Tod Michigan on June 26, 2011 at 18:31:50 from (174.252.229.9):
In Reply to: 460 Diesel Hydraulic issue, again. posted by Tod Michigan on June 22, 2011 at 12:55:45:
Power Steering(PS) is out and I did the pressure test and only produced 100psi. I get the feeling that there is no flow. I did This pressure test back when I was determining if I needed a hydraulic pump(HP). When I knew I need the HP, I wanted to check the PSP as well. When I did the test before, as I closed the valve to test for pressure, I could hear and feel that there was some flow and pressure going on behind the valve and felt like if I closed that valve something was gonna blow. But this time I could close the valve and didn't sense the presence of flow and pressure.
I just did this test and I'm gonna open the manual and stare at the ceiling tonight's trying to figure out what to do from here but my main question is should I do anything more before I drain the fluid and inspect the pump(s)?
If I don't get any response I may re-post with new topic. This topic was about hydraulic issue(s) and everyone was nice enough to help with my PS as well.
Thank you for all the help and suggestions,
Tod.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
