Re: 460 diesel POWER STEERING ISSUE
Posted by pete 23 on June 27, 2011 at 10:11:39 from (74.32.230.16):
In Reply to: Re: 460 diesel POWER STEERING ISSUE posted by Tod Michigan on June 26, 2011 at 22:06:50:
Depends on which pump you have, the cessna has flow control and relief valve incorporated inside same valve, thompson relief valve is on side of pump and flow control in more integral. At any rate, the relief valve is right in or on the pumps. And oh yes, they can crap out just like that, but remember, you could be loseing flow right through the steering bolster itself, that is why I take the return life off to see if flow just keeps on coming while trying to steer. The flow will continue up to a point but should definetly slow down if the wheels are not turning. I think I might be getting you confused now. I just kind of pick my way through trouble shooting depending on results I get so hard to explain everything.
