Re: 806 Diesel Overheating problem
Posted by RedRoundhead on June 29, 2011 at 07:08:41 from (184.216.151.248):
In Reply to: 806 Diesel Overheating problem posted by claytonmcnamara on June 28, 2011 at 19:52:27:
Is the water pump pumping? See this happen in cars with worn out water pumps. Or a small crack in head that only opens up when warm. Seen that happen, too. Good luck!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
