806 Diesel Overheating problem
Posted by claytonmcnamara on June 28, 2011 at 19:52:27 from (69.179.14.228):
Can"t seem to figure this out. Just bought this tractor and it will run a long time working it medium hard (raking hay etc.) and it will do fine. Once it gets up to about half way on the temp gauge, it slowly starts to puke antifreeze out the overflow tube, and it keeps getting hotter and puking more until i get worried and shut it off.
Today i took a garden hose and sprayed out the radiator and got some crud out. Straightened several fins that were bent and refilled it with water. Ran it a bit longer, but it still heats up after running it.
If this is a head problem, what causes it to get hot? There is no oil in antifreeze, no antifreeze in oil. Starts up super easy (not low on compression) and it runs perfect with lots of power... Can it be a thermostat?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
