H Transmission Gear Mystery
Posted by Hoosierfarmall on July 02, 2011 at 15:41:11 from (70.201.61.172):
I bought a 1947 H for parts, but it ran too good so I have yet another project... fourth gear didnt work, I assumed I would pull the lid off and find the 4th sliding gear with no teeth... what I found was a smaller 36 tooth gear, with all of it's teeth, that lacked a good quarter of an inch from engaging onto the lower 4th gear on the counter shaft?? I got a good 4th/5th of ebay, installed it today and everything works perfect. The 36T removed is stamped T136G, incidentally, the inner teeth went onto the main drive gear perfectly, and it fit the main shaft perfectly. Anyone have any ideas what it is and why it would be there? My parts book doesnt list a 36T for any specialty application for an H or for an M.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
