Re: Farmall drive train?
Posted by The tractor vet on July 04, 2011 at 17:33:26 from (99.167.210.166):
In Reply to: Re: Farmall drive train? posted by farmall706 on July 03, 2011 at 21:36:18:
The Tel tale lite is a dual purpose lite , It tells you when the engine oil pressure is low and also tells ya when you have low pressure in the MCV . SO if it is flickering ya need to know WHY . Is the engine oil pressure low at idle or is the MCV pressure low . Now if it is BLINKING then it still has the org. bulb as they were a flasher bulb. And yes you can turn it to far in and or not far enough . So and other way of setting ther dump valve is with a oil pressure gauge that will work for you and when setting the dump valve with a gauge you press the clutch pedal to the floor and hold and with the dump valve bolt backed off to where you are still showing pressure you turn it in till the gauge goes to 0 then let the pedal up and add one full turn and lock it down with the lock nut.
