Re: Farmall M drum brakes
Posted by glennster on July 05, 2011 at 12:22:56 from (75.57.140.126):
In Reply to: Farmall M drum brakes posted by Carden on July 05, 2011 at 11:29:28:
a slide hammer and a screw will pull the old seal out, you can also try and collapse the seal a little with a small chisel and pry it out. do not attemp to remove the housing that the seal fits in. the bull gear on the inside must be removed before that housing comes off. the new seals are thinner than the original, so you can move it in or out a little so it doesnt run in the groove, or double up the seals and pack grease between the seals.
