Posted by Carden on July 05, 2011 at 11:29:28 from (74.33.231.28):
I"ve had sloppy brakes, on my "51 M, with both sides being saturated with oil. Last year, I took them apart (just the bands) and tried to clean them up. The are again saturated with oil. I"m hoping some here can help. I"ve done a search and haven"t quite found the correct terms... I pulled the band covers off of both sides leaving the band in the covers. Took the single bolt off of the middle of the "drum" and slid it out. When I look in the tractor brake housing, I can see the bearing that the drum shaft slides through. On this side of the bearing (closest to me) there is a seal. It appears to be double lipped with a spring in it, that the drum shaft also slides through. I have not pulled them out yet but on one side I can see the spring hanging down slightly. One of the drum shafts is grooved. I assume from wear. The other side is smooth. When trying to find this "seal" in the YT parts I find nothing. When looking on the internet I find references to a "brake seal" and a "bull pinion" seal. Sorry for the long explanation but I figured more detail is better than less. I"m trying to be as specific as possible, to lessen any misunderstanding. 1. What is what I am looking to replace properly called, please? 2. What is the best way to get that old seal out and to put the new one in?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
