Re: Farmall M drum brakes
Posted by RPM1941 on July 05, 2011 at 13:28:33 from (173.25.71.175):
In Reply to: Farmall M drum brakes posted by Carden on July 05, 2011 at 11:29:28:
To explain what you are seeing is most likely the original seal that had 3 leather seals spring loaded within a steel stamped case,the old seals are no longer made & the replacements are single lip newer design neoprene rubber. You can install 1 to 3 new seals, usually 2 will suffice. The new seal is demensionally narrower than old but bore & outside are same.
