IH 666 with weak 3pt.
Posted by IH-Mitch on July 05, 2011 at 15:15:22 from (98.125.100.63):
I bought an IH 666 that had been used for pulling a rake and other light duty work for the past 30+ years. The problem is they never used the 3pt, and the handles for draft control and 3pt control froze up. After soaking it down with oil and leaving it for a few days they finally came free. The 3pt went up slow but did go up and goes down fine. I hooked up the bale forks to it and it has no lifting power.
When hitting the hydraulic levers you can hear the pump working, but i never tested the hydraulic pressure yet. Power steering works fine also.
So I'm not sure if I messed something up when loosing the frozen levers, hydraulic pump/ filter, stuck valve somewhere, or what.
Any help or suggestions would be appreciated.
Thanks
