That tractor has a seperate pump mounted piggy back on main pump, and relief valve for the hitch and if the hitch is not being used the flow from hitch pump joins the flow from main pump behind the aux valve mounting. There fore , when you pull aux valve and it makes tractor labor that only tells you the main pump is working and the unloading valve to hitch if most likely ok also. So, that brings you to a weak hitch pump, leaking hitch relief valve which is under the cover under seat or blown internal o-rings in draft control valves or cyl. Could possibly by action control valve sticking but I would have to feel your lever to tell you that. If your hitch will go up and down with no load and follow the positiion control lever all right ( MEANING IT WILL NOT JUST GOT ALL THE WAY TO TOP OR BOTTOM) I would think your linkages are ok.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
