560 hydraulic question
Posted by Marty from MN on July 05, 2011 at 19:49:29 from (75.73.148.235):
I'm glad this isn't my only tractor right now, I also have an electrical problem I can't chase down (see topic 560 electrical mess).
We were out cutting hay the other day with the 560 and it was running great, then after 2 hours or so it seems like the hydraulics would not unload and started dragging down the engine to the point of actually sputtering.
It has a 2pt hitch that I suspect is the problem. Anytime you touch the other 2 remotes (loader, haybine, etc) the teledepth system will start to draw on the hydraulic system until you move the control lever slightly down. That will usually unload the hydraulic system. This weekend that stopped working after 2 hours or so of running. Did the oil just overheat?
I suspect that the filter could be changed, but it has done this even after a brand new was installed. Beyond that I don't have a clue.
