Re: Fast Hitch on Farmall Super C
Posted by greg on August 09, 2000 at 08:54:23 from (205.180.71.120):
In Reply to: Fast Hitch on Farmall Super C posted by Stephen Powers on August 08, 2000 at 22:31:51:
If the term fast hitch is refering to what I think it is, the fast hitch allows you to hook up to standard three-point implements without having to get off the tractor and pin the side and top links- just lower the fast hitch to the height needed, get it located relative to the pins on the implement, raise up the tractor 3-point/fast hitch and go play in the dirt.this type of hitch is real common on row crop tractors big and small.
Post A Followup
: Re: Re: Fast Hitch on Farmall Super C
