Re: Re: Fast Hitch on Farmall Super C
Posted by Dave 2N on August 09, 2000 at 10:02:32 from (32.97.239.29):
In Reply to: Re: Fast Hitch on Farmall Super C posted by greg on August 09, 2000 at 08:54:23:
Fast Hitch referred to Farmall's own hook-up system. The drawbar was removed and that left two openings for the arms of the Fast Hitch implements. In reality, Farmall's Fast Hitch system was a 2-pt system, it was fast to hook up and was every bit as good as the 3-pt system. However, you could only use the 2-pt. implements with the Farmall Fast Hitch System whereas a 3-pt implement could be used on any tractor with a 3-pt. hitch system (with certain Case Eagle Hitch exceptions.) After reading what I just wrote, I think I have muddied the water????
Post A Followup
: Re: Re: Re: Fast Hitch on Farmall Super C
