Re: H Farmall Wiring Diagram HELP!
Posted by pete 23 on July 06, 2011 at 20:42:19 from (74.32.234.149):
In Reply to: H Farmall Wiring Diagram HELP! posted by Novice with Case on July 06, 2011 at 13:14:41:
I will just add that no IH tractor of that vintage came with a voltage regulator mounted on the generator. It was strictly a cutout with an added feature where you could hook hook up the field wire for constant low charge through a resistor right on the cutout. That was for a tractor with starter but no lights so you had no light switch. All voltage regulated H farmalls had the regulator mounted on or near steering wheel post.
