H Farmall Wiring Diagram HELP!
Posted by Novice with Case on July 06, 2011 at 13:14:41 from (198.105.65.197):
I am restoring an H Farmall to the orginal 6 volt positive ground system with all new parts from IH. The tractor came with a voltage regular mounted on the generator. The replacement light switch from IH doesn't have all the extra restistors, etc the old one did. I simply have a pole for a Battery, Front Lights, Rear lights, and 2 poles with a coil running between them. I am not using either of these poles on the switch. The lights work as they should but and the amp hand shows a discharge when turned on with out the tractor running. I have followed the instructions on the generator and voltage regulator in terms of connections and polarizing yet it will not change. Any help would be appreciated!
