Posted by freefour on July 07, 2011 at 06:33:45 from (216.124.211.18):
Got a couple simple questions about my newly purchased B. I have noticed a small fresh puddle of oil under the shifter each night after I used it. So I cleaned up all the area under and found it is leaking between the transmission connects to the front half of the tractor (see pic). Not sure what it is called.
I believe it has been leaking for a while. I want to check the oil level and make sure there is enough in there. I found the plug on the side where you check the oil level and see where you add it on top by the shifter. What type of oil should I use? I figured it uses like a 80W-90 gear oil.
Also, is there anyway to fix this or even slow it without splitting the tractor? I don't know if that is something I can tackle or have the tools to do so. Thanks!
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
