Re: oil leaks
Posted by CharlieNJ on July 07, 2011 at 11:42:02 from (76.117.68.151):
In Reply to: oil leaks posted by freefour on July 07, 2011 at 06:33:45:
When you pull the little level check plug, you will know whether there is enough oil, OR if it is overfilled. If the tractor was outside, there could be water in the transmission, that lesked in the shifter, that would bring the oil level above the seal at the transmission, which would cause the leak between the torque tube and the transmission. Check the level.
Charlie
