Re: H Farmall Wiring Diagram HELP!
Posted by tractorfacter on July 07, 2011 at 13:21:39 from (72.24.107.178):
In Reply to: H Farmall Wiring Diagram HELP! posted by Novice with Case on July 06, 2011 at 13:14:41:
I have a wire diagram for an H but it almost sounds like your voltage regulator is not working.My super A was doing that and a gentlman told me to take the cover off the voltage reg and lightly file or sand the points in there,just as you would breaker points in the dist. If your volt reg. is original, the cover should be screwed on. replacements or after markets can have rivits in that case replace. Also it is not uncommon far a discharge reading with lights on and tha engine at a low idle. Pick up the rpms a bit and see what happens to the meter.uote="Novice with Case"](reply to post at 13:14:41 07/06/11) [/quote]
