If it draws a heavy discharge when shut down and the genny gets hot THE CUTOUT RELAY IS STICKING CLOSED. In fact if you loosened or removed the belt the genny would spin like the DC motor it is........
Starting when the genny is at opposite polarity of the battery can damage a VR, you may wanna Polarize just to be sure then try it,,maybe the VR isnt damaged????
Its NORMAL if the armature is in place to get an ohm reading very low (almost like a dead short on a cheap meter) from the Gennys ARM post to case ground. If you ohm from FLD it should be more like 3 to 6 ohms to ground, however, as thats the Fields then to ground via the armature.
The Full Field test involves temporarily dead grounding the Gennys FLD post to grnd and if she charges then but not otherwise the VR is bad or its not well grounded MAKE SURE THE VR HAS A GOOD GROUND IT NEEDS IT TO WORK
Some VR's are labeled specifically for either POS or NEG ground, sure you have the right VR???
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
