Re: Cutout Relay Stuck Closed
Posted by nc140man on July 09, 2011 at 08:14:22 from (174.106.171.79):
In Reply to: Cutout Relay Stuck Closed posted by John T on July 07, 2011 at 14:41:27:
Ok, gave it a go. Tried the first suggestions and polarized the generator. Then went and polarized the regulator. Hooked wiring back up, no discharge! Fine, pulled ignition switch on, slight draw. Turned on lights, bigger draw, still not as much as before. Turned them all off, everything fine, no discharge. Started tractor, fired up fine, after a few seconds, starts showing a charge, good huh? Even tested output with meter, about 6.85 at the generator but only 6.72 at battery terminal on regulator? Normal? Let it run a few minutes still charging and no heat(did run with cover off regulator so I could observe while running)seems fine. Shut off tractor and it goes right back to high discharge on ammeter! Disconnected generator terminal to stop it from discharging and was a good spark! Still drawing at generator? Dang it!What to try?
Scott
