Farmall 100 missing a beat under load
Posted by chad from michigan on July 08, 2011 at 05:39:45 from (151.163.2.8):
Ok I have had this problem for a long time now and I think I have found it everytime.
tractor runs great under normal conditons flat ground driving and no load. If I put a fast hitch disk on her or haul a traler load of fire wood up the hill out of the river flats (which can be scarey if it stalls) it will miss a beat and then run great and another 10 seconds or so it misses a beat then runs great again and so on.
I am assuming it is a fuel delivery problem and I think it is at the carb. It seems to get a ton of gas to the carb. Could it be the float? what should I look at it? It is almost like it goes dead for a second then takes off running. I thought if it was the ignition it would do it all the time. can anyone help me with the galloping sound and loss of power on this 100 it is getting very very upsetting to have this happen when I really want to work this tractor!
