I'm all for changing plug wires if the old ones are old/inadequate. Bad plugs, and more so bad plug wires can cause a whole slew of problems that are hard to diagnose.
However, in this case the problem is only when the engine is under load.
You have to ask yourself what's different when the engine is working harder.
To me - that points more to the governor first - carb second.
If it's sparking at no load, even a weak spark SHOULD be ok under load... Again, definitely worth changing plugs and wires if they're old just to be sure.
But under load the engine slows, and the governor opens the carb for more air/fuel to bring it back up to speed.
If that doesn't happen correctly, the engine's going to have trouble.
You've probably check it over, but since you didn't mention it, I figured I'd throw my two cents in about it just to be sure.
Of course, if the governor is working fine, the carb still has to be able to deliver the fuel/air - but sounds to me like you've checked that area out pretty well.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
